Ana içeriğe geç
Repairing a Tear in a Tent
Neye ihtiyacın var
  1. Repairing a Tear in a Tent, Sew a Ladder Stitch: adım 1, 3 resimden 1. Repairing a Tear in a Tent, Sew a Ladder Stitch: adım 1, 3 resimden 2. Repairing a Tear in a Tent, Sew a Ladder Stitch: adım 1, 3 resimden 3.
    • Thread your needle and tie a knot in the end.
    • We're using contrasting thread for visibility, but when it comes time for your repair, you'll want to use matching thread.
    • Drive the needle from the back of the material, just before where the tear starts.
    • Pull the thread taut.
  2. Repairing a Tear in a Tent: adım 2, 2 resimden 1. Repairing a Tear in a Tent: adım 2, 2 resimden 2.
    • Take a small stitch, going in and out of the material, on one side of the tear only.
  3. Repairing a Tear in a Tent: adım 3, 2 resimden 1. Repairing a Tear in a Tent: adım 3, 2 resimden 2.
    • Take a small stitch, going in and out of the material, on the other side of the tear, directly opposite of the stitch you just took.
    • Pull the thread taut. This should cinch the material together.
    • If your material bunches, try taking smaller stitches, while ensuring that you line up the stitches on either side of the material.
  4. Repairing a Tear in a Tent: adım 4, 2 resimden 1. Repairing a Tear in a Tent: adım 4, 2 resimden 2.
    • Continue stitching, switching from side to side as described in step 2 and 3 of this guide, pulling the thread taut after each stitch.
    • Stitch until you come to the end of the tear.
  5. Repairing a Tear in a Tent: adım 5, 3 resimden 1. Repairing a Tear in a Tent: adım 5, 3 resimden 2. Repairing a Tear in a Tent: adım 5, 3 resimden 3.
    • One the last stitch, drive the needle through both sides of the fabric, taking as small of a stitch as possible.
    • Slowly pull the thread. As you pull, a loop will form. Draw the needle through this loop, and pull the thread taut.
    • Repeat this step, taking a tiny stitch, drawing the needle through the loop, and pulling taut.
    • Ensure that the stitches are tight, and cut any excess threads.
    Instead of cutting the excess thread, I leave enough length at the end to “bury” the long threads inside the repair, where they will not show and are less likely to loosen up.
    Kathleen Slamka - Yanıt
    We use a clear repair patch kind of tape to fix our tents called fixmytear repair tape. So much cheaper than paying a machinist to fix it. Apply it to both sides if you can for extra strength.
    https://www.amazon.com/Fixmytear-Magic-R...
    https://www.amazon.com/fixmytear-Magic-R...
    W731620 E - Yanıt
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Brittany McCrigler
89.865 İtibar
142 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.601 adet Kılavuz yazıldı
Bir Yorum
Have you seen this product? "fixmytear". It's a repair tape which sticks very well to vinyl, canvas, rubber, leather and most other surfaces. Absolutely life saving tape.
bobhunter50023 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 29
Son 30 gün: 145
Her zaman: 10,114
