Ana içeriğe geç
Replacing Atari Lynx Speaker
Neye ihtiyacın var
  1. Replacing Atari Lynx Speaker, Atari Lynx: adım 1, 1 resimden 1.
    • Before disassembling your Atari Lynx, be sure the device is powered off.
    • Remove any game in the console by opening the right latch and sliding the game to the right.
  2. Replacing Atari Lynx Speaker: adım 2, 1 resimden 1.
    • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Pinch the rear panel with your fingers and lift away from the Atari.
  3. Replacing Atari Lynx Speaker: adım 3, 1 resimden 1.
    • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear any wires attached to battery panel.
  4. Replacing Atari Lynx Speaker: adım 4, 1 resimden 1.
    • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear the speaker wire while removing the control panel.
  5. Replacing Atari Lynx Speaker, Speaker: adım 5, 2 resimden 1. Replacing Atari Lynx Speaker, Speaker: adım 5, 2 resimden 2.
    • Remove the logic board from the console.
    • Flip the logic board so the screen is facing down.
  6. Replacing Atari Lynx Speaker: adım 6, 2 resimden 1. Replacing Atari Lynx Speaker: adım 6, 2 resimden 2.
    • Now you will need to desolder both of the wires connected to the speaker.
    • If you are having trouble desoldering, click here.
    • Finally solder the new speaker back on and follow the previous steps in reverse order.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Tyler Williams
333 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-42, Maness Winter 2014 Cal Poly, Team 1-42, Maness Winter 2014 üyesi
CPSU-MANESS-W14S1G42
5 Üyeler
16 adet Kılavuz yazıldı
2 Yorum
Does anyone know the screw sizes for the lynx 2 console please
RBKing 80 - Yanıt
What are the specs on the speaker? Size? Wattage?
gregory draudt - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 1,448
