Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle
  1. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle, Cog and lockring: adım 1, 1 resimden 1.
    • Remove the 9.5mm bolts on the rear wheel with an adjustable wrench. There is a bolt on each side of the wheel.
  2. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: adım 2, 3 resimden 1. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: adım 2, 3 resimden 2. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: adım 2, 3 resimden 3.
    • Loosen the 4mm by 50.8mm chain tension screw with a hex key. There is a screw on each side of the wheel.
  3. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: adım 3, 2 resimden 1. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: adım 3, 2 resimden 2.
    • Remove the chain from the rear wheel cog. Remove the rear wheel from the frame of the bike.
  4. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: adım 4, 2 resimden 1. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: adım 4, 2 resimden 2.
    • Remove the lockring on the back tire using a lockring wrench. To loosen the lockring twist the wrench clockwise.
  5. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: adım 5, 2 resimden 1. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: adım 5, 2 resimden 2.
    • Loosen the cog using a chain whip and adjustable pliers. Rap the chain whip around the cog. Push the chain whip handle down so that the cog twists counterclockwise.
    • It will take a lot of force to loosen the cog.
  6. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: adım 6, 2 resimden 1. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: adım 6, 2 resimden 2.
    • Remove the cog the rest of the way with your hand. Replace with a new cog.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 28
Son 30 gün: 128
Her zaman: 2,972
