Ana içeriğe geç
Replacing Crosley CR42 Needle
Neye ihtiyacın var
  1. Replacing Crosley CR42 Needle, Needle: adım 1, 2 resimden 1. Replacing Crosley CR42 Needle, Needle: adım 1, 2 resimden 2.
    • The needle is the red plastic piece on the end of the arm. The needle snugly fits over the lower portion of the head, or front end, of the arm.
    FixBot'a Sor
    Yorum Ekle
  2. Replacing Crosley CR42 Needle: adım 2, 2 resimden 1. Replacing Crosley CR42 Needle: adım 2, 2 resimden 2.
    • While securing the end of the arm by holding the head in place, use your fingernail to push down on the front edge of the needle.
    • The needle should hang, as shown.
    FixBot'a Sor
    Yorum Ekle
  3. Replacing Crosley CR42 Needle: adım 3, 2 resimden 1. Replacing Crosley CR42 Needle: adım 3, 2 resimden 2.
    • Once the needle snaps free of the head of the arm, remove the needle by pulling down. Take care to only pull on the red portion.
    • WHEN ATTACHING NEW NEEDLE: Slide the back (open U shaped side) of the needle on first, then press to snap the front into place. You should hear a click.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Roberto Rosila
328 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-38, Maness Winter 2014 Cal Poly, Team 1-38, Maness Winter 2014 üyesi
CPSU-MANESS-W14S1G38
4 Üyeler
5 adet Kılavuz yazıldı
1Rehber Yorum
On the Crosley CR7002A I am having a problem with the turntable. When the tone arm is moved over any part of the record is slides back to the home position (rest). Is their any adjustment I can make to fix this? Thanks.
thmccullough - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 51
Her zaman: 5,977
