Giriş
In this replacement of the charging port, we can see the steps needed clearly, as well as how we also need to put things back in place to make the iPhone 11 work properly. I think this repair is really important for people to know about because this issue is quite common. Having a way to solve it by yourself and not spending money on the repair would be good for people to know. In this replacement, there is not a lot of hazard present, but I think you require some basic knowledge of technology to avoid getting confused.
Neye ihtiyacın var
Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
Bu adımda kullanılan alet:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone—one on the top, and one on the bottom.
Squeeze the cups together to apply suction to the desired area.
Heat an iOpener and thread it through the arms of the Anti-Clamp.
Fold the iOpener so it lays on the bottom edge of the iPhone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
Skip the next three steps.
Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
Pull the small nub on the suction cup to detach it from the front panel.
Open the iPhone by swinging the display up from the left side, like the back cover of a book.
Prop the display up against something sturdy.
Remove the 3 Y000 screws, then use a plastic spudger to disconnect the battery flex.
Unscrew the five Y000 screws securing the main logic board shield, then remove the shield
Disconnect the two display cables
Remove the three Philips screws securing the Taptic Engine
Two 1.8mm screws
One 1.9mm screw
Remove the bracket covering the Taptic Engine flex connector
Pry up on the connector to disconnect the cable from its socket
Remove the Taptic Engine
Unscrew the two Phillips screws
Remove the charging port with tweezers
Bir başkası bu kılavuzu tamamladı.
2 Yorum
Ummm, is it just me, or is he skipping a lot of steps after removing the screen? Lmao
Yes. Use this video for a complete guide:
