Ana içeriğe geç
Resetting the Palm m105
Neye ihtiyacın var
  1. Resetting the Palm m105, Device Reset: adım 1, 1 resimden 1.
    • To soft reset the device, use a paperclip to carefully press the reset button located on the back of the device. The exact location of the button can be seen in the picture.
    • A soft reset means that it will usually not affect your personal data on your device, unless the batteries are low.
    • After you press the button, the device will reboot as if you just powered on your device and it should clear up most common device problems.
    • If your device is still not powering up or has a blank display, the next step will help you perform a hard reset of the device.
    FixBot'a Sor
    Yorum Ekle
  2. Resetting the Palm m105: adım 2, 2 resimden 1. Resetting the Palm m105: adım 2, 2 resimden 2.
    • A hard reset will erase all current data on the device. This should only be done if a soft reset has not solved your problem.
    • A hard reset is done by simultaneously holding down the power button while also pressing the reset button on the back with a paper clip like you did for the soft reset. After a few seconds the Palm logo should appear, when it does, release the power button.
    • If applicable, you can restore any data previously synchronized with your PC through the HotSync operation of the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Erik Thompson
31 İtibar
5 adet Kılavuz yazıldı
Ekip
UW Stout, Team 1-3, Zhou Fall 2011 UW Stout, Team 1-3, Zhou Fall 2011 üyesi
UWSTOUT-ZHOU-F11S1G3
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 50
Her zaman: 1,943
