Ana içeriğe geç
Retro-Bit Retro Duo Reset Button/Power Switch Replacement
Neye ihtiyacın var
  1. Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: adım 1, 3 resimden 1. Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: adım 1, 3 resimden 2. Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: adım 1, 3 resimden 3.
    • With the console on its top. Remove the four 12 mm Phillips #2 screws.
    • There may be a sticker covering one, or more, of the screws. Simply remove the it before the screws.
    • Flip the console on its feet and carefully lift the top casing from the back (where the AV/S and power ports are).
    • To avoid damage, do not completely remove the top case. There is a small circuit board--which houses two LEDs-- connected to the main circuit board.
    FixBot'a Sor
    Yorum Ekle
  2. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: adım 2, 3 resimden 1. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: adım 2, 3 resimden 2. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: adım 2, 3 resimden 3.
    • Remove the one 6 mm Phillips #0 screw.
    • Lift the top case.
    • This step allows easy button access and prevents accidental damage.
    FixBot'a Sor
    Yorum Ekle
  3. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: adım 3, 3 resimden 1. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: adım 3, 3 resimden 2. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Using your fingers (or precision tweezers), carefully pinch the button tabs and push through to the other side.
    • Make sure you pinch both tabs simultaneously, or the button will not pop out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
If the problem persists after the buttons are replaced, it may be a circuit board issue. If so, please visit our guide for circuit board replacement at Retro-Bit Retro Duo Circuit Board Replacement
Truong Vo
324 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S4-G4, Eyestone Fall 2017 USF Tampa, Team S4-G4, Eyestone Fall 2017 üyesi
USFT-EYESTONE-F17S4G4
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 56
Her zaman: 1,188
