Ana içeriğe geç
Retro-Bit Retro Duo Reset Button/Power Switch Replacement
Neye ihtiyacın var
  1. Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: adım 1, 3 resimden 1. Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: adım 1, 3 resimden 2. Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: adım 1, 3 resimden 3.
    • With the console on its top. Remove the four 12 mm Phillips #2 screws.
    • There may be a sticker covering one, or more, of the screws. Simply remove the it before the screws.
    • Flip the console on its feet and carefully lift the top casing from the back (where the AV/S and power ports are).
    • To avoid damage, do not completely remove the top case. There is a small circuit board--which houses two LEDs-- connected to the main circuit board.
    FixBot'a Sor
  2. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: adım 2, 3 resimden 1. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: adım 2, 3 resimden 2. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: adım 2, 3 resimden 3.
    • Remove the one 6 mm Phillips #0 screw.
    • Lift the top case.
    • This step allows easy button access and prevents accidental damage.
    FixBot'a Sor
  3. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: adım 3, 3 resimden 1. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: adım 3, 3 resimden 2. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Using your fingers (or precision tweezers), carefully pinch the button tabs and push through to the other side.
    • Make sure you pinch both tabs simultaneously, or the button will not pop out.
    FixBot'a Sor
Sonuç
If the problem persists after the buttons are replaced, it may be a circuit board issue. If so, please visit our guide for circuit board replacement at Retro-Bit Retro Duo Circuit Board Replacement
Truong Vo
324 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S4-G4, Eyestone Fall 2017 USF Tampa, Team S4-G4, Eyestone Fall 2017 üyesi
USFT-EYESTONE-F17S4G4
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 91
Her zaman: 1,172
