Ana içeriğe geç
Revlon RVDR5061 Heating Element Assembly Replacement
Neye ihtiyacın var
  1. Revlon RVDR5061 Heating Element Assembly Replacement, Fan/Motor Assembly: adım 1, 1 resimden 1.
    • Using a Phillips #3 screwdriver, remove the single 25 mm Phillips head screw in the handle by turning it counterclockwise.
  2. Revlon RVDR5061 Heating Element Assembly Replacement: adım 2, 1 resimden 1.
    • Using a medium flathead screwdriver or better yet iFixit plastic opening tools, gently pry apart the handle from the power cord.
  3. Revlon RVDR5061 Heating Element Assembly Replacement: adım 3, 1 resimden 1.
    • After pulling apart the housing, all internals will be free to remove.
  4. Revlon RVDR5061 Heating Element Assembly Replacement: adım 4, 3 resimden 1. Revlon RVDR5061 Heating Element Assembly Replacement: adım 4, 3 resimden 2. Revlon RVDR5061 Heating Element Assembly Replacement: adım 4, 3 resimden 3.
    • The fan/motor assembly is connected to the heating element assembly at two points need to be desoldered. After pulling the attached wires through the holes the fan/motor assembly will be free from the heating element assembly. Congratulations you have now completely removed the fan/motor assembly from this hair dryer!
  5. Revlon RVDR5061 Heating Element Assembly Replacement, Heating Element Assembly: adım 5, 2 resimden 1. Revlon RVDR5061 Heating Element Assembly Replacement, Heating Element Assembly: adım 5, 2 resimden 2.
    • Once the fan/motor assembly is disconnected from the heating element assembly you will see that the heating element assembly is connected to a circuit board by four wires. The color of these wires are grey, black, purple and brown.
  6. Revlon RVDR5061 Heating Element Assembly Replacement: adım 6, 3 resimden 1. Revlon RVDR5061 Heating Element Assembly Replacement: adım 6, 3 resimden 2. Revlon RVDR5061 Heating Element Assembly Replacement: adım 6, 3 resimden 3.
    • Desolder these four wires one by one from the circuit board.
  7. Revlon RVDR5061 Heating Element Assembly Replacement: adım 7, 1 resimden 1.
    • The heating element assembly will now be separated from the circuit board and can be replaced with a new one.
Sonuç
Soneil Pitamber
97 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S2-G2, Wilson Summer 2018 IUPUI, Team S2-G2, Wilson Summer 2018 üyesi
IUPUI-WILSON-SU18S2G2
4 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 18
Her zaman: 783
