Ana içeriğe geç
Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement
gage.anastasio
gage.anastasio ve 3 diğer katkıda bulunanlar
En son May 15, 2023 tarihinde güncellendi
20 - 30 dakika
Orta
Use this guide to replace the forward/reverse switch in your Ridgid 860054 Drill.
The forward/reverse switch is also known as the rocker switch.
The forward/reverse switch allows you to change the direction in which your drill rotates. If it is damaged or otherwise unusable, you will be unable to change the direction of rotation of the drill.
Though unlikely, there may be other issues interfering with the function of the forward/reverse switch. Make sure to visit the troubleshooting guide before proceeding with the repair.
Neye ihtiyacın var
Parçalar
Aletler
  1. Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement, Ridgid R860054 Disassembly: adım 1, 2 resimden 1. Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement, Ridgid R860054 Disassembly: adım 1, 2 resimden 2.
    • Using a T10 Torx security bit, remove the ten screws from the housing assembly.
    • All of the casing screws are the same length and require the same bit.
  2. Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement: adım 2, 2 resimden 1. Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement: adım 2, 2 resimden 2.
    • Separate one half of the drill casing from the other by gently pulling both halves apart.
    • Once one half of the casing is removed, be careful! If the components are directed towards the ground, they could fall out.
  3. Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement: adım 3, 3 resimden 1. Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement: adım 3, 3 resimden 2. Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement: adım 3, 3 resimden 3.
    • Remove the plastic speed switch and forward/reverse switch by softly lifting them from the casing.
    • Remove the internal components of the drill by lightly pulling on the drill chuck.
    • All of the other electronic components are attached to the chuck, and will come out with it.
  4. Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement: adım 4, 1 resimden 1.
    • The main section of the drill should have the trigger, light indicator, and battery prongs all connected via wire. There should be two plastic switches separated from the rest of the body.
  5. Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement, Reverse and Forward Switch: adım 5, 2 resimden 1. Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement, Reverse and Forward Switch: adım 5, 2 resimden 2.
    • Remove the broken forward and backward switch by lifting it off of the trigger.
  6. Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement: adım 6, 2 resimden 1. Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement: adım 6, 2 resimden 2.
    • Replace the reverse switch with a new a switch.
    • Ensure the switch is inserted properly.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
gage.anastasio
363 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-1, Shaddix Spring 2023 UMass Dartmouth, Team 1-1, Shaddix Spring 2023 üyesi
UMASSD-SHADDIX-S23S1G1
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 31
Her zaman: 305
