Giriş
The motor helps run all the functions on the device and so if it is not working properly please view this replacement guide to learn how to replace the motor.
Neye ihtiyacın var
Pull the battery out of the case by hand before opening the device.
Using a Torx T10 screwdriver, remove the nine 6mm screws on the drill cover.
Lift off the outer casing.
Bir başkası bu kılavuzu tamamladı.
