Ana içeriğe geç
Ridgid R82005  2 Speed Gear Train  Replacement
Andrew McPherson
Andrew McPherson ve 3 diğer katkıda bulunanlar
En son April 25, 2020 tarihinde güncellendi
10 dakika
Kolay
The Ridgid R82005 speed gear switch alters the amount of power intended for specific drill-driver bits and the type of materials manipulated by operators. Forcing this tool to produce torque beyond the limits of a speed gear can cause jams that compromise the drill's versatility.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. Ridgid R82005  2 Speed Gear Train  Replacement, Housing Assembly: adım 1, 1 resimden 1.
    • Eject the battery from the drill.
    • Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
  2. Ridgid R82005  2 Speed Gear Train  Replacement: adım 2, 1 resimden 1.
    • Push the metallic Housing Connecting clip out with flat side of the plastic opening tool.
    • Eject battery before attempting this step.
  3. Ridgid R82005  2 Speed Gear Train  Replacement: adım 3, 2 resimden 1. Ridgid R82005  2 Speed Gear Train  Replacement: adım 3, 2 resimden 2.
    • Remove the top half of the Housing Assembly.
  4. Ridgid R82005  2 Speed Gear Train  Replacement: adım 4, 2 resimden 1. Ridgid R82005  2 Speed Gear Train  Replacement: adım 4, 2 resimden 2.
    • Grasp carefully the top and bottom of drill components.
    • LED light needs to be manually removed.
    • Lift and transfer, as a whole, the drill components from the old housing assembly to the new housing.
    • Make sure all drill components fit properly in the grooves of new Housing Assembly.
  5. Ridgid R82005  2 Speed Gear Train  Replacement, 2 Speed Gear Train: adım 5, 2 resimden 1. Ridgid R82005  2 Speed Gear Train  Replacement, 2 Speed Gear Train: adım 5, 2 resimden 2.
    • Remove the 2 speed gear selector by carefully lifting it out of the housing, making sure it is free from the speed switch rail.
    • The 2 speed gear selector may fall out on its own.
    • When reassembling, make sure all drill components fit properly in the grooves of the Housing Assembly.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Andrew McPherson
479 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G2, Leahy Spring 2019 USF Tampa, Team S1-G2, Leahy Spring 2019 üyesi
USFT-LEAHY-S19S1G2
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 600
