Ana içeriğe geç
Ridgid R82005 Motor Replacement
Neye ihtiyacın var
  1. Ridgid R82005  Motor Replacement, Housing Assembly: adım 1, 1 resimden 1.
    • Eject the battery from the drill.
    • Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
  2. Ridgid R82005  Motor Replacement: adım 2, 1 resimden 1.
    • Push the metallic Housing Connecting clip out with flat side of the plastic opening tool.
    • Eject battery before attempting this step.
  3. Ridgid R82005  Motor Replacement: adım 3, 2 resimden 1. Ridgid R82005  Motor Replacement: adım 3, 2 resimden 2.
    • Remove the top half of the Housing Assembly.
  4. Ridgid R82005  Motor Replacement: adım 4, 2 resimden 1. Ridgid R82005  Motor Replacement: adım 4, 2 resimden 2.
    • Grasp carefully the top and bottom of drill components.
    • LED light needs to be manually removed.
    • Lift and transfer, as a whole, the drill components from the old housing assembly to the new housing.
    • Make sure all drill components fit properly in the grooves of new Housing Assembly.
  5. Ridgid R82005  Motor Replacement, Motor: adım 5, 3 resimden 1. Ridgid R82005  Motor Replacement, Motor: adım 5, 3 resimden 2. Ridgid R82005  Motor Replacement, Motor: adım 5, 3 resimden 3.
    • Push the two pins through the motor assembly.
    • We used an Alan wrench to push the pins through, but any small tool will do.
    • Unsolder the wires from the back of the motor to free the motor from the trigger assembly.
    • To learn how to solder, check out the How to Solder and Desolder Connections guide.
    • Make sure all drill components fit properly in the grooves of the Housing Assembly.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Andrew McPherson
479 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G2, Leahy Spring 2019 USF Tampa, Team S1-G2, Leahy Spring 2019 üyesi
USFT-LEAHY-S19S1G2
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 21
Her zaman: 1,023
