Ana içeriğe geç
Ridgid R82005 Trigger Switch Replacement
Neye ihtiyacın var
  1. Ridgid R82005 Trigger Switch Replacement, Trigger Switch: adım 1, 1 resimden 1.
    • Eject the battery from the drill.
    • Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
    • Unscrew the M5x18.5mm screw if belt clip is attached.
  2. Ridgid R82005 Trigger Switch Replacement: adım 2, 1 resimden 1.
    • Push the metallic Housing Connecting clip out with flat side of the plastic spudger.
    • Eject battery before attempting this step.
  3. Ridgid R82005 Trigger Switch Replacement: adım 3, 3 resimden 1. Ridgid R82005 Trigger Switch Replacement: adım 3, 3 resimden 2. Ridgid R82005 Trigger Switch Replacement: adım 3, 3 resimden 3.
    • Remove the top half of the Housing Assembly.
    • Keep track of where the wires lead from the motor assembly to trigger switch.
    • Remove all internal components.
  4. Ridgid R82005 Trigger Switch Replacement: adım 4, 3 resimden 1. Ridgid R82005 Trigger Switch Replacement: adım 4, 3 resimden 2. Ridgid R82005 Trigger Switch Replacement: adım 4, 3 resimden 3.
    • Motor Assembly/Gearbox and Trigger Switch removed from Housing Assembly.
    • Desolder the black wire connected to the motor.
    • Flip Trigger Switch and desolder red wire.
    • To learn how to solder, use our How to Solder and Desolder Connections guide.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alex Cominos
376 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G2, Leahy Spring 2019 USF Tampa, Team S1-G2, Leahy Spring 2019 üyesi
USFT-LEAHY-S19S1G2
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 510
