Ana içeriğe geç
Rival 16131 Toaster Power Wire Repair
Neye ihtiyacın var
  1. Rival 16131 Toaster Power Wire Repair, Shell: adım 1, 2 resimden 1. Rival 16131 Toaster Power Wire Repair, Shell: adım 1, 2 resimden 2.
    • Make sure the toaster is unplugged before dissembling.
    • Turn the toaster over and remove the rubber bumper feet.
    FixBot'a Sor
    Yorum Ekle
  2. Rival 16131 Toaster Power Wire Repair: adım 2, 2 resimden 1. Rival 16131 Toaster Power Wire Repair: adım 2, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove four 12 mm screws at the base of the toaster shell.
    FixBot'a Sor
    Yorum Ekle
  3. Rival 16131 Toaster Power Wire Repair: adım 3, 3 resimden 1. Rival 16131 Toaster Power Wire Repair: adım 3, 3 resimden 2. Rival 16131 Toaster Power Wire Repair: adım 3, 3 resimden 3.
    • With the dial facing you, push the toaster base up and away until the base is just over the lip of the shell. This will disconnect the browning dial from the rest of the toaster.
    • When reassembling the toaster, make sure that the back of the dial lines up with the slot, both in position and orientation (the dial and slot are not perfect circles - they have a notch).
    • The only object holding the shell onto the toaster now is the grey part of the lever.
    FixBot'a Sor
    Yorum Ekle
  4. Rival 16131 Toaster Power Wire Repair: adım 4, 1 resimden 1.
    • Reach into the shell and grab the back white part of the lever.
    • Hold the grey lever with both your index finger and middle finger. Next, pull it.
    • Pulling too hard will break the mechanism that holds the grey handle onto the white lever.
    • Remove the shell.
    FixBot'a Sor
    Yorum Ekle
  5. Rival 16131 Toaster Power Wire Repair, Rival 16131 Toaster Power Wire Repair: adım 5, 2 resimden 1. Rival 16131 Toaster Power Wire Repair, Rival 16131 Toaster Power Wire Repair: adım 5, 2 resimden 2.
    • The power wire connects to the toaster in the area highlighted.
    • To free the wire, unscrew the two .5 inch screws, and remove the white brace.
    FixBot'a Sor
    Yorum Ekle
  6. Rival 16131 Toaster Power Wire Repair: adım 6, 1 resimden 1.
    • To solder the the wire, the circuit board has to be released.
    • To do this, unscrew the .5 inch screw located in the middle of the board.
    • Slowly lift the board up off the toaster, making sure that the red pegs that hold the board in place do not break.
    FixBot'a Sor
    Yorum Ekle
  7. Rival 16131 Toaster Power Wire Repair: adım 7, 1 resimden 1.
    • To reattach the wire, follow this solder guide.
    • Solder Guide
    FixBot'a Sor
    Yorum Ekle
Sonuç
Grant Haug
148 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-8, Propen Fall 2012 Cal Poly, Team 2-8, Propen Fall 2012 üyesi
CPSU-PROPEN-F12S2G8
5 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 38
Her zaman: 2,516
