Ana içeriğe geç
Roborock S5 Battery Replacement
Neye ihtiyacın var
    1. Roborock S5 Battery Replacement, Battery: adım 1, 3 resimden 1. Roborock S5 Battery Replacement, Battery: adım 1, 3 resimden 2. Roborock S5 Battery Replacement, Battery: adım 1, 3 resimden 3.
      • Power down your Roborock S5 vacuum.
      • Place it on a flat work surface with the wheels facing up.
      • Use a Phillips #2 screwdriver to remove the seven 14 mm screws holding the bottom cover in place.
      • Use the Phillips #2 screwdriver to loosen one captive screw holding the side brush in place.
      • Remove the side brush and set it aside for now.
      • Gently remove the bottom panel.
      FixBot'a Sor
      Yorum Ekle
    2. Roborock S5 Battery Replacement: adım 2, 1 resimden 1.
      • Lift the battery out by the two tabs on top and set it beside the robot vacuum.
      • The battery will still be attached to the robot vacuum at this point.
      FixBot'a Sor
      Yorum Ekle
    3. Roborock S5 Battery Replacement: adım 3, 3 resimden 1. Roborock S5 Battery Replacement: adım 3, 3 resimden 2. Roborock S5 Battery Replacement: adım 3, 3 resimden 3.
      • Disconnect the battery from the robot vacuum by squeezing and pulling the plug connector from the board.
      FixBot'a Sor
      Yorum Ekle
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 19
Son 7 gün: 154
Son 30 gün: 544
Her zaman: 10,929
