Ana içeriğe geç
Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement
Neye ihtiyacın var
  1. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement, How to Open the Rocketfish RF-WHTIB-A Sender: adım 1, 1 resimden 1.
    • Remove the four rubber tabs from the bottom of the sender.
    • Pull hard to peel off the rubber tabs, as they are attached with adhesive.
  2. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #1 screwdriver to unscrew the four 12 mm screws on the bottom of the device.
  3. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: adım 3, 2 resimden 1. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: adım 3, 2 resimden 2.
    • Flip the device over and remove the top casing from the sender.
  4. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement, Sender Wireless Audio Module Chip: adım 4, 1 resimden 1.
    • Use a Phillips #1 screwdriver to unscrew the 10 mm screw, securing the wireless audio module chip.
  5. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: adım 5, 1 resimden 1.
    • Use a Phillips #1 screwdriver to unscrew the 10 mm screw, securing the motherboard.
  6. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: adım 6, 1 resimden 1.
    • Use a Phillips #1 screwdriver to unscrew the two 10 mm screws located on either side of the speakers.
    • Secure the front speaker input terminal to release the motherboard.
  7. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: adım 7, 2 resimden 1. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: adım 7, 2 resimden 2.
    • Using both thumbs, push the front speaker input terminal back towards the inside part of the device.
  8. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: adım 8, 1 resimden 1.
    • Flip over the motherboard and wireless audio module chip.
  9. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: adım 9, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Gently slide the black retaining flap back, securing the ribbon wire gently away from the white bar.
    • There should only be a small separation between the white bar and the black retaining flap.
    • Tweezers are recommended for this step.
  10. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: adım 10, 1 resimden 1.
    • Using your fingers, pull the ribbon wire out from the black retaining flap in order to completely disconnect the wireless audio module chip.
  11. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement, Sender Speaker Input Terminal: adım 11, 2 resimden 1. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement, Sender Speaker Input Terminal: adım 11, 2 resimden 2.
    • Desolder the four metallic clasps that attach the panel to the motherboard.
    • For soldering techniques, follow the step in iFixit's soldering guide.
    • Do not attempt to solder if you are inexperienced.
Sonuç
To attach a new speaker input terminal, follow these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Caitlin Charlton
756 İtibar
6 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-2, Williams Spring 2015 Baylor, Team 4-2, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S4G2
3 Üyeler
Bir Yorum
Where can I get a replacement input terminal?
Greg Surrett (terminal case) - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 23
Her zaman: 2,294
