Ana içeriğe geç
Roku 2 A/C Power Port Replacement
Neye ihtiyacın var
  1. Roku 2  A/C Power Port Replacement, Roku 2 Motherboard: adım 1, 1 resimden 1.
    • Heat up the iOpener for 30 seconds in the microwave and place across rubber pads on the back of the device.
    • It may take multiple heats, left for a minute at a time, to properly loosen the glue.
  2. Roku 2  A/C Power Port Replacement: adım 2, 1 resimden 1.
    • Gently use the plastic opening tool to pry the rubber pads off.
  3. Roku 2  A/C Power Port Replacement: adım 3, 1 resimden 1.
    • Remove the four Phillips #000 screws from the bottom of the case.
  4. Roku 2  A/C Power Port Replacement: adım 4, 1 resimden 1.
    • Gently remove the under side of the device.
  5. Roku 2  A/C Power Port Replacement: adım 5, 1 resimden 1.
    • Remove the middle component that is held in place by the top and bottom of the device.
  6. Roku 2  A/C Power Port Replacement: adım 6, 1 resimden 1.
    • Remove the cover over the A/V ports on the front of the device.
  7. Roku 2  A/C Power Port Replacement: adım 7, 1 resimden 1.
    • Remove the board from the plastic enclosure.
  8. Roku 2  A/C Power Port Replacement, A/C Power Port: adım 8, 1 resimden 1.
    • Heat the 3 solder leads on the bottom side of the motherboard opposite of the A/C Port until the point you can pull the port away from the board.
    • To learn more about soldering check out the Soldering Technique Guide.
  9. Roku 2  A/C Power Port Replacement: adım 9, 1 resimden 1.
    • Insert the new A/C power port where the old one was. Gently apply solder to the 3 pins on the bottom side of the mother board to connect it.
Sonuç
david quintana
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-5, Sullivan Fall 2015 USF Tampa, Team 1-5, Sullivan Fall 2015 üyesi
USFT-SULLIVAN-F15S1G5
3 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 28
Her zaman: 1,370
