Ana içeriğe geç
Roku 2 Remote Battery Replacement
Neye ihtiyacın var
  1. Roku 2 Remote Battery Replacement, Remote Battery: adım 1, 1 resimden 1.
    • Turn over remote and press down on tab to remove.
  2. Roku 2 Remote Battery Replacement: adım 2, 1 resimden 1.
    • Remove batteries
  3. Roku 2 Remote Battery Replacement: adım 3, 1 resimden 1.
    • Place the new batteries into the remote. Make sure the positive terminal is facing the positive terminal of the slot. Similarly the negative terminal should be touching the negative terminal. If done right the batteries should be facing opposite directions of each other.
    • Insert Roku tab back on to its slot.
    No. They should be facing in the same direction, not the opposite direction. Roku does it differently than most other manufacturers.
    Alex Zavatone - Yanıt
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Alex Saltos
526 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-5, Sullivan Fall 2015 USF Tampa, Team 1-5, Sullivan Fall 2015 üyesi
USFT-SULLIVAN-F15S1G5
3 Üyeler
7 adet Kılavuz yazıldı
1Rehber Yorum
Now Roku remotes comes with various features. To access these features you have to pair the Roku remote. If you want any help regarding Roku remote go to website: Roku Com Link
Katherine Melinda - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 31
Her zaman: 6,592
