Ana içeriğe geç
Roku 3 Ethernet Port Replacement
Neye ihtiyacın var
  1. Roku 3 Ethernet Port Replacement, Motherboard: adım 1, 1 resimden 1.
    • Place the Roku 3 on the table face down and orient it so you can correctly read the writing.
  2. Roku 3 Ethernet Port Replacement: adım 2, 3 resimden 1. Roku 3 Ethernet Port Replacement: adım 2, 3 resimden 2. Roku 3 Ethernet Port Replacement: adım 2, 3 resimden 3.
    • Pull back the rubber protection in the top right corner to locate the screw.
    • Repeat with the bottom right corner and bottom left corner.
  3. Roku 3 Ethernet Port Replacement: adım 3, 1 resimden 1.
    • Remove the 9 mm screws from the three corners with a Hex 1.3 Screwdriver.
  4. Roku 3 Ethernet Port Replacement: adım 4, 2 resimden 1. Roku 3 Ethernet Port Replacement: adım 4, 2 resimden 2.
    • Open the device by gently lifting the bottom half away from the top half of the device.
  5. Roku 3 Ethernet Port Replacement: adım 5, 1 resimden 1.
    • Use your fingers to carefully lift the motherboard from the top half of the device.
  6. Roku 3 Ethernet Port Replacement: adım 6, 2 resimden 1. Roku 3 Ethernet Port Replacement: adım 6, 2 resimden 2.
    • Pull away the IO shield from the motherboard using your hands.
  7. Roku 3 Ethernet Port Replacement, Ethernet Port: adım 7, 2 resimden 1. Roku 3 Ethernet Port Replacement, Ethernet Port: adım 7, 2 resimden 2.
    • Turn over the motherboard so the back is face up and almost all large silver components are resting facedown on the table.
    • Orient it such that the backside of the HDMI port is in your upper right corner.
  8. Roku 3 Ethernet Port Replacement: adım 8, 1 resimden 1.
    • Desolder all of the port's connections with a soldering iron.
    • For more information on soldering, check out iFixit's Soldering Guide.
  9. Roku 3 Ethernet Port Replacement: adım 9, 2 resimden 1. Roku 3 Ethernet Port Replacement: adım 9, 2 resimden 2.
    • Locate the plastic push-throughs just to the left of the backside of the USB port.
    • Pinch the plastic push-throughs. The port should now be able to be removed.
Sonuç
Andy Hak
268 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-2, Livingston Fall 2016 Cal Poly, Team 15-2, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S15G2
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 30
Her zaman: 1,674
