Ana içeriğe geç
Roku XD 2050X Composite Video Port Replacement
Neye ihtiyacın var
  1. Roku XD 2050X Composite Video Port Replacement, Case: adım 1, 3 resimden 1. Roku XD 2050X Composite Video Port Replacement, Case: adım 1, 3 resimden 2. Roku XD 2050X Composite Video Port Replacement, Case: adım 1, 3 resimden 3.
    • Ensure the Roku XDis unplugged.
    • Take care when handling components. Circuit boards, soldering points, and other areas may have sharp points.
    • Turn the device upside down.
    • Remove the two rubber pads using a plastic spudger.
  2. Roku XD 2050X Composite Video Port Replacement: adım 2, 2 resimden 1. Roku XD 2050X Composite Video Port Replacement: adım 2, 2 resimden 2.
    • Remove the two Phillips #1 9mm pan-head screws.
  3. Roku XD 2050X Composite Video Port Replacement: adım 3, 3 resimden 1. Roku XD 2050X Composite Video Port Replacement: adım 3, 3 resimden 2. Roku XD 2050X Composite Video Port Replacement: adım 3, 3 resimden 3.
    • Insert spudger between upper and lower frame underneath the port access.
    • Guide spudger around to loosen upper and lower frame to pry frame apart.
    • Gently remove upper frame.
  4. Roku XD 2050X Composite Video Port Replacement: adım 4, 2 resimden 1. Roku XD 2050X Composite Video Port Replacement: adım 4, 2 resimden 2.
    • Remove the two Phillips #1 8mm pan-head screws.
  5. Roku XD 2050X Composite Video Port Replacement: adım 5, 1 resimden 1.
    • On the side of the board opposite the ports, find and tilt back the tab securing the board in place.
    • Lift the motherboard out of the lower frame.
  6. Roku XD 2050X Composite Video Port Replacement, Composite Video Port: adım 6, 1 resimden 1.
    • Desolder the leads for the composite video port that are circled.
    • Remove the video port from the board.
    • For help with soldering view the iFixit soldering guide.
Sonuç
Bir başkası bu kılavuzu tamamladı.
William
1.603 İtibar
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 27
Her zaman: 649
