Ana içeriğe geç
Roku XD 2050X Remote Battery Terminal Replacement
Neye ihtiyacın var
  1. Roku XD 2050X Remote Battery Terminal Replacement, Remote Control Casing: adım 1, 2 resimden 1. Roku XD 2050X Remote Battery Terminal Replacement, Remote Control Casing: adım 1, 2 resimden 2.
    • Take care when handling components. Circuit boards, soldering points, and other areas may have sharp points.
    • Remove the battery cover.
    • Remove the two AA batteries.
  2. Roku XD 2050X Remote Battery Terminal Replacement: adım 2, 2 resimden 1. Roku XD 2050X Remote Battery Terminal Replacement: adım 2, 2 resimden 2.
    • Insert flat edge of spudger into seam between the top and bottom halves of the remote control.
    • Gently twist the spudger to separate the top and bottom halves of the remote.
  3. Roku XD 2050X Remote Battery Terminal Replacement: adım 3, 1 resimden 1.
    • Gently use the spudger to pry the circuit board loose.
  4. Roku XD 2050X Remote Battery Terminal Replacement: adım 4, 1 resimden 1.
    • Using either end of the spudger, gently lift and remove the clear keypad backing.
  5. Roku XD 2050X Remote Battery Terminal Replacement: adım 5, 1 resimden 1.
    • Using either end of the spudger, lift and remove the rubber keypad.
  6. Roku XD 2050X Remote Battery Terminal Replacement, Remote Battery Terminal: adım 6, 1 resimden 1.
    • Desolder the contacts for the battery terminals.
    • Remove the battery terminals from the circuit board.
    • For hep with soldering view the ifixit soldering guide.
Sonuç
William
1.603 İtibar
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 1,422
