Ana içeriğe geç
Roku XD 2050X Remote IR LED Replacement
Neye ihtiyacın var
  1. Roku XD 2050X Remote IR LED Replacement, Remote Control Casing: adım 1, 2 resimden 1. Roku XD 2050X Remote IR LED Replacement, Remote Control Casing: adım 1, 2 resimden 2.
    • Take care when handling components. Circuit boards, soldering points, and other areas may have sharp points.
    • Remove the battery cover.
    • Remove the two AA batteries.
    FixBot'a Sor
    Yorum Ekle
  2. Roku XD 2050X Remote IR LED Replacement: adım 2, 2 resimden 1. Roku XD 2050X Remote IR LED Replacement: adım 2, 2 resimden 2.
    • Insert flat edge of spudger into seam between the top and bottom halves of the remote control.
    • Gently twist the spudger to separate the top and bottom halves of the remote.
    FixBot'a Sor
    Yorum Ekle
  3. Roku XD 2050X Remote IR LED Replacement: adım 3, 1 resimden 1.
    • Gently use the spudger to pry the circuit board loose.
    FixBot'a Sor
    Yorum Ekle
  4. Roku XD 2050X Remote IR LED Replacement: adım 4, 1 resimden 1.
    • Using either end of the spudger, gently lift and remove the clear keypad backing.
    FixBot'a Sor
    Yorum Ekle
  5. Roku XD 2050X Remote IR LED Replacement: adım 5, 1 resimden 1.
    • Using either end of the spudger, lift and remove the rubber keypad.
    FixBot'a Sor
    Yorum Ekle
  6. Roku XD 2050X Remote IR LED Replacement, Remote IR LED: adım 6, 1 resimden 1.
    • Desolder the two contacts for the IR LED.
    • Remove the IR LED from the circuit board.
    • For help with soldering view the ifixit soldering guide.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
William
1.603 İtibar
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 31
Her zaman: 1,193
