Ana içeriğe geç
Roller Blade Washer Replacement
Humza Khan
Humza Khan ve 2 diğer katkıda bulunanlar
En son April 19, 2023 tarihinde güncellendi
9 - 25 dakika
Kolay
Adım Kırpıcı
Daha iyi giriş
To do this replacement you need to make sure you have the correct size allen wrench and the washer fits properly because each roller blade has different specifications. If you do not put the washer on correctly it could cause the wheels to not spin as freely as they should. This fix is neccesary because if the washer is warped the wheels wont spin well or at all causing the front wheel to lock up.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Roller Blade Washer Replacement, Washer: adım 1, 1 resimden 1.
    • The roller blade needs to be side down on a flat surface
  2. Roller Blade Washer Replacement: adım 2, 1 resimden 1.
    • Use an Allen Wrench to unscrew the screws on each side of the wheel.
  3. Roller Blade Washer Replacement: adım 3, 1 resimden 1.
    • Remove the screws and wheel from the blade.
  4. Roller Blade Washer Replacement: adım 4, 1 resimden 1.
    • Take the old plastic washer off the long screw.
  5. Roller Blade Washer Replacement: adım 5, 1 resimden 1.
    • Retrieve the new plastic washer and insert between the blades on the inner side. Do the same to the other side, so that both sides have new plastic washers
  6. Roller Blade Washer Replacement: adım 6, 1 resimden 1.
    • Replace the wheel without dislodging the new plastic washers and center the hole of the wheel in each plastic washer.
  7. Roller Blade Washer Replacement: adım 7, 1 resimden 1.
    • Reinsert the screws through the plastic washers and wheel.
  8. Roller Blade Washer Replacement: adım 8, 1 resimden 1.
    • Lastly, tighten the screws with the Allen Wrench.
Sonuç
You just finished replacing the plastic washers, you can now go out and skate to your hearts content
Bir başkası bu kılavuzu tamamladı.
Humza Khan
125 İtibar
1 Kılavuz yazıldı
Ekip
3 Yorum
ভিঢা বাজার অগ্রণী ব্যাংকের
হাসিবুর রহমান - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 2,511
