Ana içeriğe geç
Roofing Tile  Replacement
Jonathan Fuentes
Jonathan Fuentes ve 2 diğer katkıda bulunanlar
En son February 19, 2025 tarihinde güncellendi
30 dakika - 2 saat
Orta
Gramer Polisi
İşlem Görüntüleri
Metin kafa karıştırıcı
Öğrenci İş Başında
A broken tile on an incomplete tile roof will be repaired through this guide. Roofing tiles are not only a sore thumb to look at but can also cause detrimental effects resulting in roof leaks and water damage. This guide is a general overview on repairing a tile roof.
Be careful when working on a roof as falls from a great height are possible. Use a safety harness to avoid accidents.
  1. Roofing Tile  Replacement, Roofing Tile: adım 1, 1 resimden 1.
    • Be cautious when climbing the ladder to the roof. Ensure your ladder is secure before climbing.
    • Ensure the damage has not reached the underlayment.
  2. Roofing Tile  Replacement: adım 2, 1 resimden 1.
    • Depending on where the damaged tile is on the roof, be sure to prime underlayment before adding new roof tile on top.
  3. Roofing Tile  Replacement: adım 3, 1 resimden 1.
    • Carefully remove the damaged tile(s) using your hammer & crow bar.
    • Be sure to use an effective safety harness when operating in unsafe conditions.
  4. Roofing Tile  Replacement: adım 4, 1 resimden 1.
    • Use roof cement to initially attach the tiles to each other & to add security to the underlayment.
    • Be sure to wear the proper gear, such as: shoes, hats, & breathable clothing.
  5. Roofing Tile  Replacement: adım 5, 3 resimden 1. Roofing Tile  Replacement: adım 5, 3 resimden 2. Roofing Tile  Replacement: adım 5, 3 resimden 3.
    • Secure the tile to the cement by pressing down on the tile using the handle of the hammer.
    • Use the handle of the hammer to maneuver into correct position.
    • As seen in the bottom of the picture, using too much cement can leak out from both sides of the tile. Be sure to keep it as hidden underneath the tile as possible.
    • Safety first. Don't forget to wear a harness and be sure to understand handling of cement take.
  6. Roofing Tile  Replacement: adım 6, 1 resimden 1.
    • Walk carefully on the tiles that are already set into place.
  7. Roofing Tile  Replacement: adım 7, 1 resimden 1.
    • Using the backside of the hammer to slide up the piece overlapping the broken one and using a drill to unscrew any screws (which won't be necessary if you're using roof cement). Replace the tile with the new one and glue in place.
  8. Roofing Tile  Replacement: adım 8, 1 resimden 1.
    • This is an initial point of view for replacing a single broken tile. You can see the application of roof cement in the crevice of the tile.
Sonuç
Number one thing of importance is your safety, my goal is for this guide to give you a general idea of the steps it takes to construct/repair/replace a tile roof.
Bir başkası bu kılavuzu tamamladı.
Jonathan Fuentes
187 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 58
Her zaman: 797
