Ana içeriğe geç
Ryobi CSB125 Blade Replacement
Neye ihtiyacın var
    1. Ryobi CSB125 Blade Replacement, Blade: adım 1, 1 resimden 1.
      • Place the saw down on a flat surface with the blade facing up.
      • Make sure that the saw is unplugged from any power source.
      FixBot'a Sor
      Yorum Ekle
    2. Ryobi CSB125 Blade Replacement: adım 2, 2 resimden 1. Ryobi CSB125 Blade Replacement: adım 2, 2 resimden 2.
      • Use the 7”/32 allen key to loosen the 5/16-18 x 9/16 in. blade screw.
      FixBot'a Sor
      Yorum Ekle
    3. Ryobi CSB125 Blade Replacement: adım 3, 1 resimden 1.
      • Remove the 5/16-18 x 9/16 in. blade screw, spring washer, and the outer blade washer.
      FixBot'a Sor
      Yorum Ekle
    4. Ryobi CSB125 Blade Replacement: adım 4, 1 resimden 1.
      • Remove the blade from the saw.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Curtis Melo
1.093 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G1, Barthe Fall 2019 UMass Dartmouth, Team S2-G1, Barthe Fall 2019 üyesi
UMASSD-BARTHE-F19S2G1
3 Üyeler
1Rehber Yorum
I think this is the wrong title.these instructions show how to remove the blade NOT replace it.
Prenston Gale Sr - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 30
Her zaman: 2,201
