Ana içeriğe geç
Ryobi CSB125 Motor Replacement
Neye ihtiyacın var
    1. Ryobi CSB125 Motor Replacement, Motor: adım 1, 1 resimden 1.
      • Place the saw on a flat surface with the blade facing up.
      • Make sure that the saw is unplugged from any power source.
      FixBot'a Sor
      Yorum Ekle
    2. Ryobi CSB125 Motor Replacement: adım 2, 2 resimden 1. Ryobi CSB125 Motor Replacement: adım 2, 2 resimden 2.
      • Remove the bumper by using the T20 torx screwdriver to loosen the M5 x 20mm screw.
      FixBot'a Sor
      Yorum Ekle
    3. Ryobi CSB125 Motor Replacement: adım 3, 2 resimden 1. Ryobi CSB125 Motor Replacement: adım 3, 2 resimden 2.
      • Use the 7”/32 allen key to loosen the 5/16-18 x 9/16 in. blade screw.
      FixBot'a Sor
      Yorum Ekle
    4. Ryobi CSB125 Motor Replacement: adım 4, 1 resimden 1.
      • Remove the 5/16-18 x 9/16 in. blade screw, spring washer, the outer blade washer, the blade, and the inner blade washer.
      FixBot'a Sor
      Yorum Ekle
    5. Ryobi CSB125 Motor Replacement: adım 5, 3 resimden 1. Ryobi CSB125 Motor Replacement: adım 5, 3 resimden 2. Ryobi CSB125 Motor Replacement: adım 5, 3 resimden 3.
      • Use the #2 Phillip screwdriver to remove the four M4x16mm screws shown.
      • You will need to rotate the protective shell around in order to access them.
      FixBot'a Sor
      Yorum Ekle
    6. Ryobi CSB125 Motor Replacement: adım 6, 1 resimden 1.
      • Remove the lower blade guard support assembly from the rest of the saw.
      FixBot'a Sor
      Yorum Ekle
    7. Ryobi CSB125 Motor Replacement: adım 7, 1 resimden 1.
      • Flip the saw over and place the saw down on a flat surface with the motor facing up.
      FixBot'a Sor
      Yorum Ekle
    8. Ryobi CSB125 Motor Replacement: adım 8, 1 resimden 1.
      • Use the Phillips #2 screwdriver to remove the five M4x16mm screws.
      FixBot'a Sor
      Yorum Ekle
    9. Ryobi CSB125 Motor Replacement: adım 9, 1 resimden 1.
      • Use the Phillips #2 screwdriver to remove the two M45x35mm screws.
      FixBot'a Sor
      Yorum Ekle
    10. Ryobi CSB125 Motor Replacement: adım 10, 2 resimden 1. Ryobi CSB125 Motor Replacement: adım 10, 2 resimden 2.
      • Use the Phillips #2 screwdriver to remove the two M4x16mm screws holding down the end cover.
      • Pull off the end cover.
      FixBot'a Sor
      Yorum Ekle
    11. Ryobi CSB125 Motor Replacement: adım 11, 1 resimden 1.
      • Use the Phillips #2 screwdriver to remove the M45x35mm screw holding down the motor housing.
      FixBot'a Sor
      Yorum Ekle
    12. Ryobi CSB125 Motor Replacement: adım 12, 1 resimden 1.
      • Remove the motor housing for access to the internal motor components.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Curtis Melo
1.093 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G1, Barthe Fall 2019 UMass Dartmouth, Team S2-G1, Barthe Fall 2019 üyesi
UMASSD-BARTHE-F19S2G1
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 43
Her zaman: 1,171
