Ana içeriğe geç
Ryobi CSB125 Power Cord Replacement
Neye ihtiyacın var
  1. Ryobi CSB125 Power Cord Replacement, Power Cord: adım 1, 1 resimden 1.
    • Place the saw down on a flat surface with the motor facing up.
    • Make sure that the saw is unplugged from any power source.
    FixBot'a Sor
    Yorum Ekle
  2. Ryobi CSB125 Power Cord Replacement: adım 2, 2 resimden 1. Ryobi CSB125 Power Cord Replacement: adım 2, 2 resimden 2.
    • Use the Phillips #2 screwdriver to remove the five M4x16mm screws.
    FixBot'a Sor
    Yorum Ekle
  3. Ryobi CSB125 Power Cord Replacement: adım 3, 1 resimden 1.
    • Use the Phillips #2 screwdriver to remove the two M45x35mm screws.
    FixBot'a Sor
    Yorum Ekle
  4. Ryobi CSB125 Power Cord Replacement: adım 4, 2 resimden 1. Ryobi CSB125 Power Cord Replacement: adım 4, 2 resimden 2.
    • To remove the plug from the saw you will need to disconnect the two wires that come from the plug.
    • Remove the black wire by unscrewing it from the trigger switch using the Phillips #2 screwdriver.
    • Remove the white wire by twisting off the plastic wire nut to separate the two white wires.
    FixBot'a Sor
    Yorum Ekle
  5. Ryobi CSB125 Power Cord Replacement: adım 5, 1 resimden 1.
    • Remove the plug from the saw.
    • You may have to use the wire strippers to expose the copper on the new plug.
    • It is important that the wires are properly run in their tracks. Failure to do so could result in pinching a wire, which could damage the plug.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Curtis Melo
1.093 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G1, Barthe Fall 2019 UMass Dartmouth, Team S2-G1, Barthe Fall 2019 üyesi
UMASSD-BARTHE-F19S2G1
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 48
Her zaman: 2,240
