Ana içeriğe geç
Ryobi CSB125 Trigger Replacement
Neye ihtiyacın var
    1. Ryobi CSB125 Trigger Replacement, Trigger: adım 1, 1 resimden 1.
      • Place the saw down on a flat surface with the motor facing up.
      • Make sure that the saw is unplugged from any power source.
      FixBot'a Sor
      Yorum Ekle
    2. Ryobi CSB125 Trigger Replacement: adım 2, 2 resimden 1. Ryobi CSB125 Trigger Replacement: adım 2, 2 resimden 2.
      • Use the Phillips #2 screwdriver to remove the five M4x16mm screws.
      FixBot'a Sor
      Yorum Ekle
    3. Ryobi CSB125 Trigger Replacement: adım 3, 1 resimden 1.
      • Use the Phillips #2 screwdriver to remove the two M45x35mm screws.
      FixBot'a Sor
      Yorum Ekle
    4. Ryobi CSB125 Trigger Replacement: adım 4, 1 resimden 1.
      • Disconnect the two black wires by unscrewing them from the trigger switch using the Phillips #2 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    5. Ryobi CSB125 Trigger Replacement: adım 5, 1 resimden 1.
      • Remove the trigger from the saw.
      • You may have to use the wire strippers to the copper on the new plug.
      • It is important that the wires are properly run in their tracks. Failure to do so could result in pinching a wire, which could damage the plug.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Curtis Melo
1.093 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G1, Barthe Fall 2019 UMass Dartmouth, Team S2-G1, Barthe Fall 2019 üyesi
UMASSD-BARTHE-F19S2G1
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 25
Her zaman: 897
