Giriş
This guide will show you how to properly replace the blade guard in the Ryobi CSB135L. If the symptoms in our troubleshooting page for a malfunctioning guard align with the symptoms your Ryobi CSB135L are experiencing your guard is most likely damaged. This guide will show you how to replace it.
Neye ihtiyacın var
Remove the central 6mm hex nut and two black washers using a 6mm allen wrench.
Remove the old blade.
Remove the M5 x 20 mm screw using a Phillips screwdriver.
Remove the black rubber stopper.
Bir başkası bu kılavuzu tamamladı.
