Ana içeriğe geç
Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement
Neye ihtiyacın var
  1. Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement, Battery: adım 1, 3 resimden 1. Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement, Battery: adım 1, 3 resimden 2. Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement, Battery: adım 1, 3 resimden 3.
    • Detach the battery unit from the drill body and pull the battery outwards.
    • If the battery doesn't disconnect easily, gently wiggle the battery back and forth until it comes out.
  2. Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement, Housing Assembly: adım 2, 1 resimden 1.
    • Remove ten 13.5 mm screws from the drill casing using a Phillips #2 screwdriver to gain access to the interior.
  3. Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement: adım 3, 3 resimden 1. Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement: adım 3, 3 resimden 2. Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement: adım 3, 3 resimden 3.
    • Grab the sides of the housing and pull straight up until the housing pulls away revealing the inside assembly.
  4. Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement, Trigger: adım 4, 3 resimden 1. Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement, Trigger: adım 4, 3 resimden 2. Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement, Trigger: adım 4, 3 resimden 3.
    • Gently lift the battery clip to gain access to the trigger.
    • You can now clean any debris blocking the trigger.
Sonuç
Robert Campbell
73 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 26
Her zaman: 278
