Ana içeriğe geç
Ryobi P271 Reverse Switch Replacement
Neye ihtiyacın var
  1. Ryobi P271 Reverse Switch Replacement, Battery: adım 1, 3 resimden 1. Ryobi P271 Reverse Switch Replacement, Battery: adım 1, 3 resimden 2. Ryobi P271 Reverse Switch Replacement, Battery: adım 1, 3 resimden 3.
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
    FixBot'a Sor
    Yorum Ekle
  2. Ryobi P271 Reverse Switch Replacement, Reverse Switch: adım 2, 1 resimden 1.
    • Remove all ten Torx screws from the drill's case.
    FixBot'a Sor
    Yorum Ekle
  3. Ryobi P271 Reverse Switch Replacement: adım 3, 1 resimden 1.
    • Gently pull the casing apart.
    • Separating the casing too quickly could cause internals to become loose, and not easily seat together upon reassembly.
    FixBot'a Sor
    Yorum Ekle
  4. Ryobi P271 Reverse Switch Replacement: adım 4, 1 resimden 1.
    • Remove the trigger so that it can fully expose the reverse switch.
    FixBot'a Sor
    Yorum Ekle
  5. Ryobi P271 Reverse Switch Replacement: adım 5, 1 resimden 1.
    • Firmly grab the reverse switch and pull on it until it comes out of its socket.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
nathan krehbiel
229 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G6, Barthe Fall 2019 UMass Dartmouth, Team S2-G6, Barthe Fall 2019 üyesi
UMASSD-BARTHE-F19S2G6
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 26
Her zaman: 1,864
