Ana içeriğe geç
Ryobi P271 Trigger Replacement
Neye ihtiyacın var
  1. Ryobi P271 Trigger Replacement, Battery: adım 1, 3 resimden 1. Ryobi P271 Trigger Replacement, Battery: adım 1, 3 resimden 2. Ryobi P271 Trigger Replacement, Battery: adım 1, 3 resimden 3.
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
    FixBot'a Sor
    Yorum Ekle
  2. Ryobi P271 Trigger Replacement, Trigger: adım 2, 1 resimden 1.
    • Remove the screws from the drill's casing to gain access to the interior.
    FixBot'a Sor
    Yorum Ekle
  3. Ryobi P271 Trigger Replacement: adım 3, 1 resimden 1.
    • Lift and remove the casing off of the drill body.
    FixBot'a Sor
    Yorum Ekle
  4. Ryobi P271 Trigger Replacement: adım 4, 1 resimden 1.
    • Carefully lift and remove the battery clip, trigger, motor, and everything connected to the wires and pull straight out of the drill.
    FixBot'a Sor
    Yorum Ekle
  5. Ryobi P271 Trigger Replacement: adım 5, 1 resimden 1.
    • Separate the wiring from the trigger and the motor using a soldering iron and them replace them with a new trigger and motor by soldering the wires back together.
    • Follow this guide for soldering tips.
    FixBot'a Sor
    Yorum Ekle
Sonuç
nathan krehbiel
229 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G6, Barthe Fall 2019 UMass Dartmouth, Team S2-G6, Barthe Fall 2019 üyesi
UMASSD-BARTHE-F19S2G6
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 31
Her zaman: 907
