Ana içeriğe geç
Ryobi P271 Trigger Replacement
Neye ihtiyacın var
  1. Ryobi P271 Trigger Replacement, Battery: adım 1, 3 resimden 1. Ryobi P271 Trigger Replacement, Battery: adım 1, 3 resimden 2. Ryobi P271 Trigger Replacement, Battery: adım 1, 3 resimden 3.
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
  2. Ryobi P271 Trigger Replacement, Trigger: adım 2, 1 resimden 1.
    • Remove the screws from the drill's casing to gain access to the interior.
  3. Ryobi P271 Trigger Replacement: adım 3, 1 resimden 1.
    • Lift and remove the casing off of the drill body.
  4. Ryobi P271 Trigger Replacement: adım 4, 1 resimden 1.
    • Carefully lift and remove the battery clip, trigger, motor, and everything connected to the wires and pull straight out of the drill.
  5. Ryobi P271 Trigger Replacement: adım 5, 1 resimden 1.
    • Separate the wiring from the trigger and the motor using a soldering iron and them replace them with a new trigger and motor by soldering the wires back together.
    • Follow this guide for soldering tips.
Sonuç
nathan krehbiel
229 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G6, Barthe Fall 2019 UMass Dartmouth, Team S2-G6, Barthe Fall 2019 üyesi
UMASSD-BARTHE-F19S2G6
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 31
Her zaman: 576
