Ana içeriğe geç
Ryobi P277 Reversing Switch Replacement
Neye ihtiyacın var
  1. Ryobi P277 Reversing Switch Replacement, Reversing Switch: adım 1, 2 resimden 1. Ryobi P277 Reversing Switch Replacement, Reversing Switch: adım 1, 2 resimden 2.
    • Lay the device on its side with the warning label facing you.
    • Remove the eight 5 mm screws using a TR10 Torx screwdriver.
    • Separate the two halves of the casing by pulling up on the top half.
    • The two halves are still attached, so use caution when opening the device.
    FixBot'a Sor
    Yorum Ekle
  2. Ryobi P277 Reversing Switch Replacement: adım 2, 1 resimden 1.
    • The reversing switch lies between the trigger and the motor.
    • Carefully remove the reversing switch from the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Kailyn Hammond Gouch
85 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 36
Her zaman: 443
