Ana içeriğe geç
Ryobi P277 Trigger Replacement
Neye ihtiyacın var
  1. Ryobi P277 Trigger Replacement, Trigger: adım 1, 2 resimden 1. Ryobi P277 Trigger Replacement, Trigger: adım 1, 2 resimden 2.
    • Lay the device on its side.
    • Remove eight 5 mm screws using a TR10 Torx screwdriver.
    • Separate the two halves by pulling up on the top half.
    • The two halves are still attached, so use caution when opening the device.
    FixBot'a Sor
    Yorum Ekle
  2. Ryobi P277 Trigger Replacement: adım 2, 1 resimden 1.
    • Use a Phillips head screwdriver to remove this bracket.
    FixBot'a Sor
    Yorum Ekle
  3. Ryobi P277 Trigger Replacement: adım 3, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. You must use solder to reattach the wires in their correct positions.
Alexander Farbo
281 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 8
Son 30 gün: 25
Her zaman: 907
