Ana içeriğe geç
Ryobi P277 Trigger Replacement
Neye ihtiyacın var
  1. Ryobi P277 Trigger Replacement, Trigger: adım 1, 2 resimden 1. Ryobi P277 Trigger Replacement, Trigger: adım 1, 2 resimden 2.
    • Lay the device on its side.
    • Remove eight 5 mm screws using a TR10 Torx screwdriver.
    • Separate the two halves by pulling up on the top half.
    • The two halves are still attached, so use caution when opening the device.
  2. Ryobi P277 Trigger Replacement: adım 2, 1 resimden 1.
    • Use a Phillips head screwdriver to remove this bracket.
  3. Ryobi P277 Trigger Replacement: adım 3, 1 resimden 1.
Sonuç
To reassemble your device, follow these instructions in reverse order. You must use solder to reattach the wires in their correct positions.
Alexander Farbo
281 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 9
Her zaman: 629
