Giriş
Use this guide to remove and replace the motor on your Ryobi P517 reciprocating saw.
The motor is the source that powers the cutting mechanism of the saw. The motor moves the reciprocating mechanism of the saw, which converts the rotational motion of the motor to linear, reciprocating motion. The saw blade then moves in this reciprocating motion to allow for cutting. The motor’s variable speed capability allows for greater control over cutting. The motor needs to be replaced when it fails due to use, overheating, or electrical issues. Additionally, if the motor is physically damaged due to misuse or improper storage, it will need to be replaced. A poorly installed motor can interfere with the saw’s cutting power and efficiency.
Before reading this guide, please review the Ryobi P517 Troubleshooting Page to ensure that your issue cannot be resolved externally, without removing the motor. Remove the housing assembly before beginning the motor removal process.
Neye ihtiyacın var
Position the saw so you can access the button-clips on both sides of the battery.
Lay the saw flat so the left side is facing up.
Remove the grey orbital button by twisting it counterclockwise.
Position the saw so the ports connecting the circuit board assembly to the motor are accessible.
Firmly grasp the motor in one hand while holding the gear case in your opposite hand.
Disconnect the motor from the gear case by firmly pulling the two pieces apart.
Bir başkası bu kılavuzu tamamladı.
