Ana içeriğe geç
SEGA Genesis Flashback Controller Buttons Replacement
Neye ihtiyacın var
  1. SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: adım 1, 3 resimden 1. SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: adım 1, 3 resimden 2. SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: adım 1, 3 resimden 3.
    • Hold the controller with the bottom plate facing up, and gently remove the top plate that is connected to the motherboard of the controller. Set the top plate aside.
    • Remove the screws on the back of the controller with the Phillips #000 screwdriver.
    • Be sure to separate the two plates with the bottom facing up, to keep the buttons from falling out.
  2. SEGA Genesis Flashback Controller Buttons Replacement, Controller Buttons: adım 2, 2 resimden 1. SEGA Genesis Flashback Controller Buttons Replacement, Controller Buttons: adım 2, 2 resimden 2.
    • CAUTION: Pull gently on the rubber membranes to avoid tearing .
    • Use two fingers to remove each rubber membrane that rests on top of the buttons.
  3. SEGA Genesis Flashback Controller Buttons Replacement: adım 3, 1 resimden 1.
    • Pop the button out from the front side of the controller.
    • Pull the button out from the backside using the other hand.
    • All removable buttons can only be placed in their respective holes due to unique groove patterns on the buttons. Keep in mind where each button belongs to make re-assembly easier.
    • All buttons can be removed except for the D-Pad.
  4. SEGA Genesis Flashback Controller Buttons Replacement: adım 4, 1 resimden 1.
    • Repeat Step 3 for the remaining buttons.
    • The button should pop out seamlessly and placed to the side.
    • Repeat the prior steps in order to remove all the buttons. Set them aside in an order you will remember to where they belong.
Sonuç
After completing step 4 you will need to re-assemble your controller. Do this by starting from step 2 and work backwards. Take your e-waste to an R2 or e-Stewards certified recycler.
Bir başkası bu kılavuzu tamamladı.
Viet Nguyen
220 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S24-G12, Maness Spring 2018 Cal Poly, Team S24-G12, Maness Spring 2018 üyesi
CPSU-MANESS-S18S24G12
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 25
Her zaman: 1,831
