Ana içeriğe geç
SEGA Genesis Flashback Controller Buttons Replacement
Neye ihtiyacın var
  1. SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: adım 1, 3 resimden 1. SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: adım 1, 3 resimden 2. SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: adım 1, 3 resimden 3.
    • Hold the controller with the bottom plate facing up, and gently remove the top plate that is connected to the motherboard of the controller. Set the top plate aside.
    • Remove the screws on the back of the controller with the Phillips #000 screwdriver.
    • Be sure to separate the two plates with the bottom facing up, to keep the buttons from falling out.
    FixBot'a Sor
    Yorum Ekle
  2. SEGA Genesis Flashback Controller Buttons Replacement, Controller Buttons: adım 2, 2 resimden 1. SEGA Genesis Flashback Controller Buttons Replacement, Controller Buttons: adım 2, 2 resimden 2.
    • CAUTION: Pull gently on the rubber membranes to avoid tearing .
    • Use two fingers to remove each rubber membrane that rests on top of the buttons.
    FixBot'a Sor
    Yorum Ekle
  3. SEGA Genesis Flashback Controller Buttons Replacement: adım 3, 1 resimden 1.
    • Pop the button out from the front side of the controller.
    • Pull the button out from the backside using the other hand.
    • All removable buttons can only be placed in their respective holes due to unique groove patterns on the buttons. Keep in mind where each button belongs to make re-assembly easier.
    • All buttons can be removed except for the D-Pad.
    FixBot'a Sor
    Yorum Ekle
  4. SEGA Genesis Flashback Controller Buttons Replacement: adım 4, 1 resimden 1.
    • Repeat Step 3 for the remaining buttons.
    • The button should pop out seamlessly and placed to the side.
    • Repeat the prior steps in order to remove all the buttons. Set them aside in an order you will remember to where they belong.
    FixBot'a Sor
    Yorum Ekle
Sonuç
After completing step 4 you will need to re-assemble your controller. Do this by starting from step 2 and work backwards. Take your e-waste to an R2 or e-Stewards certified recycler.
Bir başkası bu kılavuzu tamamladı.
Viet Nguyen
220 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S24-G12, Maness Spring 2018 Cal Poly, Team S24-G12, Maness Spring 2018 üyesi
CPSU-MANESS-S18S24G12
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 51
Her zaman: 2,222
