Ana içeriğe geç
SM Santa Marin hand watch Battery Replacement
Neye ihtiyacın var
  1. SM Santa Marin hand watch Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Take apart the steel strap for the watch by using the round head (SIM) screwdriver. Then pull out the screw.
  2. SM Santa Marin hand watch Battery Replacement: adım 2, 1 resimden 1.
    • Remove four screws from the back cover using the Y000 screwdriver .
  3. SM Santa Marin hand watch Battery Replacement: adım 3, 1 resimden 1.
    • Remove the back cover of the watch using the opening tool.
  4. SM Santa Marin hand watch Battery Replacement: adım 4, 1 resimden 1.
    • Remove the plastic gasket from on top of the battery using the opening tool.
  5. SM Santa Marin hand watch Battery Replacement: adım 5, 1 resimden 1.
    • Loosen the battery bracket from the watch by placing the 1mm flathead screwdriver under and lifting carefully.
  6. SM Santa Marin hand watch Battery Replacement: adım 6, 2 resimden 1. SM Santa Marin hand watch Battery Replacement: adım 6, 2 resimden 2.
    • Take the old battery out using the plastic opening tool or spudger.
Sonuç
Aziz Zabarmawi
133 İtibar
1 Kılavuz yazıldı
Bir Yorum
It's amazing and also work as a machenic for me
Talha - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 888
