Ana içeriğe geç
SONY ZS-BTG900 Bluetooth Module Replacement
Neye ihtiyacın var
  1. SONY ZS-BTG900 Bluetooth Module Replacement, SONY ZS-BTG900 Disassembly: adım 1, 2 resimden 1. SONY ZS-BTG900 Bluetooth Module Replacement, SONY ZS-BTG900 Disassembly: adım 1, 2 resimden 2.
    • Lift up the handle to reveal the screws.
    • Use your Phillips #2 screwdriver to remove the eight 1/2 inch screws.
  2. SONY ZS-BTG900 Bluetooth Module Replacement: adım 2, 3 resimden 1. SONY ZS-BTG900 Bluetooth Module Replacement: adım 2, 3 resimden 2. SONY ZS-BTG900 Bluetooth Module Replacement: adım 2, 3 resimden 3.
    • Flip your device over.
    • Use your Phillips #2 screwdriver to remove the six 3/4inch screws.
    • In removing the screws within the two holes on the back of the device, you may want to use your shaft extension to provide extra torque as they may be very tight.
  3. SONY ZS-BTG900 Bluetooth Module Replacement: adım 3, 2 resimden 1. SONY ZS-BTG900 Bluetooth Module Replacement: adım 3, 2 resimden 2.
    • Flip your device back over to access the top of the device.
    • Use your plastic opening tool to pry up and remove the panel on the top, left hand side of the device.
    • This will reveal two additional screws.
  4. SONY ZS-BTG900 Bluetooth Module Replacement: adım 4, 1 resimden 1.
    • Use your Phillips #2 screwdriver to remove the two 1/2 inch screws underneath the now-removed panels.
  5. SONY ZS-BTG900 Bluetooth Module Replacement: adım 5, 2 resimden 1. SONY ZS-BTG900 Bluetooth Module Replacement: adım 5, 2 resimden 2.
    • Lift off the top, beginning from the back of the device.
    • Take care when lifting the top portion as there are many wires connected to the inside of the device and you do not want to disconnect these just yet.
  6. SONY ZS-BTG900 Bluetooth Module Replacement: adım 6, 2 resimden 1. SONY ZS-BTG900 Bluetooth Module Replacement: adım 6, 2 resimden 2.
    • Disconnect the CD drive ribbon cable from the top of the device.
  7. SONY ZS-BTG900 Bluetooth Module Replacement: adım 7, 2 resimden 1. SONY ZS-BTG900 Bluetooth Module Replacement: adım 7, 2 resimden 2.
    • Disconnect the antenna cables.
  8. SONY ZS-BTG900 Bluetooth Module Replacement: adım 8, 3 resimden 1. SONY ZS-BTG900 Bluetooth Module Replacement: adım 8, 3 resimden 2. SONY ZS-BTG900 Bluetooth Module Replacement: adım 8, 3 resimden 3.
    • Disconnect the remaining cables from the motherboard.
  9. SONY ZS-BTG900 Bluetooth Module Replacement: adım 9, 2 resimden 1. SONY ZS-BTG900 Bluetooth Module Replacement: adım 9, 2 resimden 2.
    • Once you have removed the top, we will begin removing the front of the device.
    • Begin by disconnecting the 6 cables that lead from the front of the device to the motherboard.
  10. SONY ZS-BTG900 Bluetooth Module Replacement: adım 10, 1 resimden 1.
    • Use your Philips #2 screwdriver to remove the two 1 inch screws on the outermost part of the device.
    • Use your Philips #2 screwdriver to remove the two 3/4 inch screws on the outermost part of the device.
    • Use your Philips #2 screwdriver to remove the one 5/6 inch screw on the middle part of the device.
  11. SONY ZS-BTG900 Bluetooth Module Replacement: adım 11, 2 resimden 1. SONY ZS-BTG900 Bluetooth Module Replacement: adım 11, 2 resimden 2.
    • Firmly pull off the front of device.
    • There will be a small amount of black glue. You can simply ignore this, and continue to pull, or use a sharp edge to cut the glue once you've revealed it.
  12. SONY ZS-BTG900 Bluetooth Module Replacement, Bluetooth Module: adım 12, 3 resimden 1. SONY ZS-BTG900 Bluetooth Module Replacement, Bluetooth Module: adım 12, 3 resimden 2. SONY ZS-BTG900 Bluetooth Module Replacement, Bluetooth Module: adım 12, 3 resimden 3.
    • Lift the plastic tab on the ribbon cable on the bluetooth module using the spudger.
  13. SONY ZS-BTG900 Bluetooth Module Replacement: adım 13, 2 resimden 1. SONY ZS-BTG900 Bluetooth Module Replacement: adım 13, 2 resimden 2.
    • Pull the ribbon cable out to remove it.
  14. SONY ZS-BTG900 Bluetooth Module Replacement: adım 14, 2 resimden 1. SONY ZS-BTG900 Bluetooth Module Replacement: adım 14, 2 resimden 2.
    • Use a Phillips #0 screwdriver to unscrew the single 1/4 inch screw.
  15. SONY ZS-BTG900 Bluetooth Module Replacement: adım 15, 3 resimden 1. SONY ZS-BTG900 Bluetooth Module Replacement: adım 15, 3 resimden 2. SONY ZS-BTG900 Bluetooth Module Replacement: adım 15, 3 resimden 3.
    • Gently grab the top and lift the chip up to remove it.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alfredo Rodriguez
972 İtibar
8 adet Kılavuz yazıldı
2 Yorum
Where did you get the Bluetooth module?
Victor - Yanıt
Great fix it article. Thank you. I, too am wondering where to get the replacement Bluetooth module? Part number as well. Thank you very much.
jwalkermark - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 1,044
