Ana içeriğe geç
Saeco Royal Pressure Relief Valve rebuild
Neye ihtiyacın var
  1. Saeco Royal Pressure Relief Valve rebuild, Preparing: adım 1, 1 resimden 1.
    • Unplug!
    • Remove all attachments like water tank, brewing unit etc.
    • The pictures show a Royal Cappucino One Touch HD8930, but the opening procedure is similar to all models.
    Um „nur“ das Supportventil auszutauschen gibt es noch eine sehr viel einfachere Vorgehensweise. Dabei setzt man an das untere Ende des Supportventils einfach mit einem 7er Gabelschlüssel an und schraubt dieses raus. Bei einigen Modellen wie der Spidem Trevi Chiara gibt es zusätzlich eine Plastikfront um das Ventil, welche sich abhebeln lässt um noch besser an das Ventil zu kommen. Gleichzeitig kann man dann auch am oberen Ende einen 17er Ringschlüssel ansetzen.
    ChuckNorris - Yanıt
  2. Saeco Royal Pressure Relief Valve rebuild, Top: adım 2, 2 resimden 1. Saeco Royal Pressure Relief Valve rebuild, Top: adım 2, 2 resimden 2.
    • The coffeebean supply is fixed with two screws. Unscrew them and lift it off.
    • There is a black rubber lid under the bean hopper that you can easily lift off, leaving a large opening.
    • The adjuster of the grinder has to be solved. Mark the position or just take a picture. This type is fixed with a screw, others are only sticked together.
    I have a Saeco Royal SUP016R model. Just cleaned the brew unit and a 1cm rubber seal fell off and i have no idea where it came from. Now there is some leak on top of the brew unit and the coffee ratio is off. Can you please help?
    Jelim - Yanıt
    To have an idea, I would need to see a picture. Use this guide: Adding images to an existing question
    VauWeh -
  3. Saeco Royal Pressure Relief Valve rebuild, Rear side: adım 3, 1 resimden 1.
    • There are two screws to be turned out.
  4. Saeco Royal Pressure Relief Valve rebuild, Front: adım 4, 3 resimden 1. Saeco Royal Pressure Relief Valve rebuild, Front: adım 4, 3 resimden 2. Saeco Royal Pressure Relief Valve rebuild, Front: adım 4, 3 resimden 3.
    • The screws are situated on the underneath of the cover. This type is held by four screws.
  5. Saeco Royal Pressure Relief Valve rebuild, Lift cover off: adım 5, 2 resimden 1. Saeco Royal Pressure Relief Valve rebuild, Lift cover off: adım 5, 2 resimden 2.
    • Now the cover can be raised: first grip on left and right rear side and lift about 10 cm (4 in). Sometimes the cover jams a little bit.
    • Solve the hoses which lead to the water tank. Perhaps you have to pull out some contacts, (e.g. the yellow-green protection lead), don´t forget to put them on again later.
    • The cover can be drawn aslant towards the front, sliding it over the hot water pipe.
    • Most repairs can be done with the cover being laid up partially , it must not be completely removed.
  6. Saeco Royal Pressure Relief Valve rebuild, Pump replacement: adım 6, 2 resimden 1. Saeco Royal Pressure Relief Valve rebuild, Pump replacement: adım 6, 2 resimden 2.
    • Here the pump viewed from above, a Ulka EX5 with 230V. The pump is stored in rubber pieces.
    • Pull the silicone hose off the rear elbow.
    • If not already done, remove the clamp on the pressure hose on the pressure relief valve. Then remove the pressure hose.
    • The pressure hose is sealed with two O-rings at the end. These will usually hang at the end. Replace them before re-assembling.
  7. Saeco Royal Pressure Relief Valve rebuild: adım 7, 3 resimden 1. Saeco Royal Pressure Relief Valve rebuild: adım 7, 3 resimden 2. Saeco Royal Pressure Relief Valve rebuild: adım 7, 3 resimden 3.
    • In the first picture, the pump has already been removed. The red marking shows the catch that holds the rubber molded part. You can easily pull it out when the catch is pressed down.
    • Pull the angled molded rubber parts out of their spots on the floor.
    • Lift the pump with the rubber moldings out of the machine.
    • When reassembling, make sure that the molded rubber part is correctly attached.
  8. Saeco Royal Pressure Relief Valve rebuild, Replacing the pump: adım 8, 1 resimden 1.
    • Unscrew the pressure relief valve with two wrenches SW 10 and 13.
    • Only the pump itself as well as the relief valve will remain.
    • If you want to replace the pump, you'll have to transfer the pressure relief valve to the new pump. You should also service your valve while you're at it.
  9. Saeco Royal Pressure Relief Valve rebuild, Pressure Relief valve rebuild: adım 9, 1 resimden 1.
    • The pressure relief valve can be opened with a 10mm open-end wrench. The screws can be very tight.
    • The complete pressure relief valve consist of the valve body, the valve spring, the valve piston with seal, and the outlet. Note: the valve stem must face towards the pressure, not as shown in the picture.
  10. Saeco Royal Pressure Relief Valve rebuild: adım 10, 3 resimden 1. Saeco Royal Pressure Relief Valve rebuild: adım 10, 3 resimden 2. Saeco Royal Pressure Relief Valve rebuild: adım 10, 3 resimden 3.
    • Check if the piston is stuck. If it is it will be necessary to free it.
    • Look at the seal: is there a deep circular groove pressed into it? If so, then it is possible that it does not close properly anymore.
    • The whole valve can be replaced with a new one.
    • It is also possible to gently pry out the seal with a needle and then turn it over. The back of the seal will seal properly if it is flat and smooth. Picture two and three show the front and back.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
de en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
VauWeh
252.667 İtibar
286 adet Kılavuz yazıldı
Ekip
Repair is War on Entropy Repair is War on Entropy üyesi
Community
29 Üyeler
1.764 adet Kılavuz yazıldı
3Kılavuz Yorumları
Moin,
kurze frage ist der Zwickel nicht eingeklebt? (Deswegen evtl. auch schwergängig) und müsste dieser, wenn ja dann nicht auch wieder eingeklebt werden?
PS: Im Schritt 21 ist im Bild die Ventilfeder und der Ventilstempel verkehrt herum. Der Stempel muss zuerst in das Gehäuse. Die Kräfte von Feder und Wasser müssen gegeneinander auf den Stempel einwirken, nicht gemeinsam.
So wie es auf dem Bild gezeigt ist, öffnet dieses Sicherheitsventil z.b bei einer Verstopfung nicht mehr und einer der Teflonschläuche wird platzen. Was dann dazu führt, dass unkontrolliert Wasser in der Maschine rumspritzt. Mit glück hat kein Mensch in diesem Moment mit der Maschine kontakt und eine Sicherung fliegt sofort. Von dem anderen Scenario reden wir mal nicht.
Grüße
Unbekannte Lebensform - Yanıt
Danke für den Hinweis. Natürlich liegt der Stempel in Bild 21 falschrum und muss zum Druck hin zeigen. Ich habe den Stutzen bisher noch nie eingeklebt, keine Probleme.
VauWeh -
Das Bild ist jetzt richtig. Der Stempel zeigt zur Pumpe hin.
VauWeh -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 65
Her zaman: 4,058
