Ana içeriğe geç
Samsung 27E510C Audio Jack Replacement
Neye ihtiyacın var
  1. Samsung 27E510C Audio Jack Replacement, Back Panel: adım 1, 3 resimden 1. Samsung 27E510C Audio Jack Replacement, Back Panel: adım 1, 3 resimden 2. Samsung 27E510C Audio Jack Replacement, Back Panel: adım 1, 3 resimden 3.
    • Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
    • The screw alone with the ports is a different size than the rest, its length is 12mm.
  2. Samsung 27E510C Audio Jack Replacement: adım 2, 2 resimden 1. Samsung 27E510C Audio Jack Replacement: adım 2, 2 resimden 2.
    • Insert the heavy duty spudger in between the monitors back panel and its frame.
    • Use the heavy duty spudger to pry open the back panel.
    • Over aggressive prying could break the tabs holding the back panel in place.
  3. Samsung 27E510C Audio Jack Replacement, Motherboard: adım 3, 1 resimden 1.
    • Remove the navigation button connector by pulling while holding down its thumb tab.
  4. Samsung 27E510C Audio Jack Replacement: adım 4, 1 resimden 1.
    • Remove the screen connector by gripping its sides and gently pulling while wiggling back and forth.
  5. Samsung 27E510C Audio Jack Replacement: adım 5, 3 resimden 1. Samsung 27E510C Audio Jack Replacement: adım 5, 3 resimden 2. Samsung 27E510C Audio Jack Replacement: adım 5, 3 resimden 3.
    • For the ribbon cable, Lift the tab from the side facing the inside of the mother board with your fingernail or a spudger.
    • Remove the cable by pulling while lifting slightly.
    • If the cable does not come out easily, than the secure tab may not be fully opened.
  6. Samsung 27E510C Audio Jack Replacement: adım 6, 3 resimden 1. Samsung 27E510C Audio Jack Replacement: adım 6, 3 resimden 2. Samsung 27E510C Audio Jack Replacement: adım 6, 3 resimden 3.
    • Remove each of the 5mm length screws attaching the motherboard to the body of the monitor using a #1 Phillips head screwdriver.
  7. Samsung 27E510C Audio Jack Replacement: adım 7, 2 resimden 1. Samsung 27E510C Audio Jack Replacement: adım 7, 2 resimden 2.
    • Using both hands, lift the board off of the monitor body by the motherboards base.
  8. Samsung 27E510C Audio Jack Replacement, Audio Jack: adım 8, 2 resimden 1. Samsung 27E510C Audio Jack Replacement, Audio Jack: adım 8, 2 resimden 2.
    • Desolder each of the indicated leads on the back of the motherboard.
  9. Samsung 27E510C Audio Jack Replacement: adım 9, 2 resimden 1. Samsung 27E510C Audio Jack Replacement: adım 9, 2 resimden 2.
    • Squeeze the rear tabs located on the back of the motherboard with your thumb and index finger.
    • While squeezing both tabs, pull the audio jack out from the front of the motherboard.
    • The audio jack may be too hot to touch right after desoldering.
Sonuç
Cesar Morales
101 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S9-G1, Banghart Fall 2017 Cal Poly, Team S9-G1, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S9G1
6 Üyeler
14 adet Kılavuz yazıldı
Bir Yorum
did you know port reference? @cesarmorales
Jorge Casanova - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 17
Her zaman: 448
