Giriş
The power adapter port allows power input to the display. The port may need to be replaced if trying a new power adapter cable does not fix display issues.
Neye ihtiyacın var
Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
Remove the navigation button connector by pulling while holding down its thumb tab.
Bir başkası bu kılavuzu tamamladı.
