Ana içeriğe geç
Samsung 500C ChromeBook Battery Replacement
Neye ihtiyacın var
  1. Samsung 500C ChromeBook Battery Replacement, Battery: adım 1, 2 resimden 1. Samsung 500C ChromeBook Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Use the spudger to remove the four rubber feet on the bottom panel.
    • Remove the seven Philips #1 screws.
  2. Samsung 500C ChromeBook Battery Replacement: adım 2, 3 resimden 1. Samsung 500C ChromeBook Battery Replacement: adım 2, 3 resimden 2. Samsung 500C ChromeBook Battery Replacement: adım 2, 3 resimden 3.
    • Remove the seven Phillips #1 screws holding the battery in place.
    • Detach the battery connector by pulling the connector towards the battery.
    • Pull from the plastic connector, do not pull from the wires.
    • Remove the battery.
    • When reinserting the battery, it is easier to insert from the long end first before lowering the rest of the battery into place.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Garrett Kissinger
704 İtibar
5 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-2, Lauer Spring 2014 Michigan Tech, Team 1-2, Lauer Spring 2014 üyesi
MTU-LAUER-S14S1G2
3 Üyeler
10 adet Kılavuz yazıldı
3Kılavuz Yorumları
Samsung 500C ChromeBook Battery where to buy?
Uzi Naveh - Yanıt
I keep typing charger and all you is replacing the battery. Without a charger I can't know if the battery is bad. Can you help or not???
Carol South - Yanıt
Don't show my NAME
Carol South - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 3,426
