Ana içeriğe geç
Samsung ATIV Book 4 Mouse Pad Replacement
Neye ihtiyacın var
  1. Samsung ATIV Book 4 Mouse Pad Replacement, Mouse Pad: adım 1, 3 resimden 1. Samsung ATIV Book 4 Mouse Pad Replacement, Mouse Pad: adım 1, 3 resimden 2. Samsung ATIV Book 4 Mouse Pad Replacement, Mouse Pad: adım 1, 3 resimden 3.
    • Place the computer upside down.
    • Remove the two rubber pads, by prying up on them.
    • There may be adhesive holding them down.
    • Remove the seven 6.5mm screws on exterior of computer.
    • Remove panel by sliding it down and lifting it away from the computer.
  2. Samsung ATIV Book 4 Mouse Pad Replacement: adım 2, 1 resimden 1.
    • Remove the four 4.4mm screws that are underneath the panel.
    • Remove the two 6.5mm screws that were underneath the rubber pads.
  3. Samsung ATIV Book 4 Mouse Pad Replacement: adım 3, 2 resimden 1. Samsung ATIV Book 4 Mouse Pad Replacement: adım 3, 2 resimden 2.
    • Using plastic opening tool, pry plastic panel away from computer.
    • Start prying at one point and work your way around the entire computer until panel is free come computer.
    • Remove the panel from computer once all tabs are broke free.
  4. Samsung ATIV Book 4 Mouse Pad Replacement: adım 4, 2 resimden 1. Samsung ATIV Book 4 Mouse Pad Replacement: adım 4, 2 resimden 2.
    • Pull this tab outwards, as shown, to release the wire harness.
    • With the tab now pulled out, pull lightly on the blue tape, to remove the harness.
    • Pull on the blue tape to remove wire harness.
    • This harness may require a little more force to remove, but will slide right out.
    • Remove the two 3.5mm screws and remove the defective hardware.
    • This step may be easier if the battery is taken out. Follow the battery replacement guide to do so.
Sonuç
Daniel
342 İtibar
3 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-7, Lauer Spring 2015 Michigan Tech, Team 1-7, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G7
2 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 1,094
