Ana içeriğe geç
Samsung ATIV Smart PC 500T Battery Replacement
Neye ihtiyacın var
    1. Samsung ATIV Smart PC 500T Battery Replacement, Backplate: adım 1, 2 resimden 1. Samsung ATIV Smart PC 500T Battery Replacement, Backplate: adım 1, 2 resimden 2.
      • Remove the stylus from the device.
      • Place the device screen-up on a hard surface, like a table.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung ATIV Smart PC 500T Battery Replacement: adım 2, 3 resimden 1. Samsung ATIV Smart PC 500T Battery Replacement: adım 2, 3 resimden 2. Samsung ATIV Smart PC 500T Battery Replacement: adım 2, 3 resimden 3.
      • Insert a plastic pry tool or opening pick between the glass and plastic case.
      • Work your way around the plastic edge, unclipping the backplate.
      • Once the clips are loosened, remove the backplate. Some force may be necessary.
      • Though you may need to use force, be careful of the pry tool slipping and hurting you!
      FixBot'a Sor
      Yorum Ekle
    1. Samsung ATIV Smart PC 500T Battery Replacement, Battery: adım 3, 3 resimden 1. Samsung ATIV Smart PC 500T Battery Replacement, Battery: adım 3, 3 resimden 2. Samsung ATIV Smart PC 500T Battery Replacement, Battery: adım 3, 3 resimden 3.
      • Disconnect the three ribbon cables from the motherboard to free the battery.
      • Use your finger to lift the flap securing each ZIF connector.
      • Slide the ribbon cable out and towards you. Now it should be completely detached.
      • Repeat with the other two cables.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung ATIV Smart PC 500T Battery Replacement: adım 4, 3 resimden 1. Samsung ATIV Smart PC 500T Battery Replacement: adım 4, 3 resimden 2. Samsung ATIV Smart PC 500T Battery Replacement: adım 4, 3 resimden 3.
      • Get a firm hold of the power cable as close to the clip as you can.
      • Pull the power cable up and out of the clip.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung ATIV Smart PC 500T Battery Replacement: adım 5, 3 resimden 1. Samsung ATIV Smart PC 500T Battery Replacement: adım 5, 3 resimden 2. Samsung ATIV Smart PC 500T Battery Replacement: adım 5, 3 resimden 3.
      • Remove the six 3.5-mm screws using the Phillips #00 screwdriver.
      • Lift the battery out by hooking your finger under the tab on the top side of the battery and pulling it up and towards you. The battery should come out easily.
      FixBot'a Sor
      Yorum Ekle
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
Crystal Dinh
1.062 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team 6-6, Williams Fall 2015 Baylor, Team 6-6, Williams Fall 2015 üyesi
BU-WILLIAMS-F15S6G6
3 Üyeler
10 adet Kılavuz yazıldı
5Kılavuz Yorumları
Thanks! Now i won't screw it up asm's destroy expensive technology like i normally do fumbling my way through these types of things!
lynz318 - Yanıt Paylaş
Awesome! Thanks for this! I managed to replace the battery, but it still won't power on. It was water damaged a while back. Any ideas on next component to try replacing?
joeshuer - Yanıt Paylaş
Do you have a battery for the Samsung ATIV Smart PC 700T1C?
calebjmartin - Yanıt Paylaş
If you're lucky, you'll replace the battery & off you go.
Unfortunately, a whole LOT of folks do this, to no avail.
If you pop for the new battery, keep the packing as new as you can in case it's NOT the issue-- at least you might recoup some of the money on Ebay.
After that, also sell your tablet on Ebay for parts because, with some units, you can change out parts all day long & it'll just never run again. Better to count your losses & do some homework this time to hopefully buy a more dependable product.
This series is just shocking at how many people have dead tablets in TWO years!
Shame on Samsung, for not recalling them. I guess they're big enough not to care....
girldownunder - Yanıt Paylaş
I got my ativ500t last 2014. After a year, the dock is not working anymore. I went to the service center and paid because it's beyond warranty, but they could not solve the problem. They told me the motherboard was broken. After a yr?! Motherboard broken?! Since I cannot do anything about it, I just ditched the dock and used it as a tab, but less frequently. Now, after barely 3 yrs, it will not turn on. Nothing happened to it. It did not get wet or fell. It just fell dead suddenly. I cannot bear to say this, but I was wrong when I purchased this product. I did not get the value I paid for. It is on the pricey tablet pcs, but it did not even last for 3 full yrs considering I do not even use it that much because I have a PC and smartphone. I am very disappointed with samsung and its service center. Shame.
Razel Elaine Grace Cataluña - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 25
Son 30 gün: 83
Her zaman: 20,234
