Ana içeriğe geç
Samsung Alias 2 Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Alias 2 Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Press down on the back cover of the phone and remove it.
  2. Samsung Alias 2 Motherboard Replacement: adım 2, 1 resimden 1.
    • Take out the battery from the device.
  3. Samsung Alias 2 Motherboard Replacement, Motherboard: adım 3, 1 resimden 1.
    • Use a Phillips screwdriver to remove the four 4.2 mm screws from the four corners of the battery slot.
  4. Samsung Alias 2 Motherboard Replacement: adım 4, 1 resimden 1.
    • Use a plastic opening tool to peel off the Verizon logo tab from the top of the back cover.
    • The tab is secured with glue, so peel it off gently.
  5. Samsung Alias 2 Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the three 4.3 mm screws that are now exposed using a Phillips screwdriver.
  6. Samsung Alias 2 Motherboard Replacement: adım 6, 1 resimden 1.
    • Use the plastic opening tool to remove the back outside casing.
    • Be careful not to lose the side buttons, as they may come off when removing the casing.
  7. Samsung Alias 2 Motherboard Replacement: adım 7, 1 resimden 1.
    • Gently pull up the yellow tab to prepare for disconnecting components.
  8. Samsung Alias 2 Motherboard Replacement: adım 8, 1 resimden 1.
    • Use tweezers to disconnect the connecting cord.
  9. Samsung Alias 2 Motherboard Replacement: adım 9, 1 resimden 1.
    • Disconnect the rectangular ribbon cable by carefully pulling it out of its connector.
  10. Samsung Alias 2 Motherboard Replacement: adım 10, 1 resimden 1.
    • Carefully lift and remove the logic board from the device.
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Bir başkası bu kılavuzu tamamladı.
Chris
133 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-35, Maness Spring 2011 Cal Poly, Team 12-35, Maness Spring 2011 üyesi
CPSU-MANESS-S11S12G35
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 21
Her zaman: 2,819
