Ana içeriğe geç
Samsung Chromebook 3 Display Replacement
Neye ihtiyacın var
  1. Samsung Chromebook 3 Display Replacement, Bottom Case: adım 1, 2 resimden 1. Samsung Chromebook 3 Display Replacement, Bottom Case: adım 1, 2 resimden 2.
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Chromebook 3 Display Replacement: adım 2, 3 resimden 1. Samsung Chromebook 3 Display Replacement: adım 2, 3 resimden 2. Samsung Chromebook 3 Display Replacement: adım 2, 3 resimden 3.
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Chromebook 3 Display Replacement: adım 3, 1 resimden 1.
    • Lift the case up and off the device
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Chromebook 3 Display Replacement, Battery: adım 4, 2 resimden 1. Samsung Chromebook 3 Display Replacement, Battery: adım 4, 2 resimden 2.
    • Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Chromebook 3 Display Replacement: adım 5, 2 resimden 1. Samsung Chromebook 3 Display Replacement: adım 5, 2 resimden 2.
    • Use a spudger to gently pry the power cable cord upwards from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Chromebook 3 Display Replacement: adım 6, 1 resimden 1.
    • Lift the battery up and out from the case.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Chromebook 3 Display Replacement, Display: adım 7, 3 resimden 1. Samsung Chromebook 3 Display Replacement, Display: adım 7, 3 resimden 2. Samsung Chromebook 3 Display Replacement, Display: adım 7, 3 resimden 3.
    • Disengage the gold connector joining the display and motherboard by flipping up the hinge with a spudger and gently disconnecting it with a spudger or your fingers.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung Chromebook 3 Display Replacement: adım 8, 3 resimden 1. Samsung Chromebook 3 Display Replacement: adım 8, 3 resimden 2. Samsung Chromebook 3 Display Replacement: adım 8, 3 resimden 3.
    • Next disconnect the small coaxial cables from the wireless chip on the daughterboard by prying upwards with a spudger.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung Chromebook 3 Display Replacement: adım 9, 2 resimden 1. Samsung Chromebook 3 Display Replacement: adım 9, 2 resimden 2.
    • Flip up at least one side of the adhesive tape holding the coaxial cables in place. When the display is removed, the cables are coming with it!
    FixBot'a Sor
    Yorum Ekle
  10. Samsung Chromebook 3 Display Replacement: adım 10, 2 resimden 1. Samsung Chromebook 3 Display Replacement: adım 10, 2 resimden 2.
    • Finally, remove the four 4.6mm screws from the display mounts using a Phillips #00 screwdriver.
    • It might be easier to open the laptop before removing these screws as the display will only come off while in the open position.
    FixBot'a Sor
    Yorum Ekle
  11. Samsung Chromebook 3 Display Replacement: adım 11, 1 resimden 1.
    • Open the laptop and remove the display.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Austin Blakely
23.087 İtibar
53 adet Kılavuz yazıldı
3Kılavuz Yorumları
Any idea as to what kind of connector the display has to the motherboard? Or how many pins? Trying to tear down the display and see if I can use it as an extra monitor.
Sam Rall - Yanıt Paylaş
It looks like there are 40 pins on the display connector. I’m not sure what it would be called or if it’s any kind of standard. If you do manage to convert the display to an extra monitor, you should definitely let us know though!
Austin Blakely - Yanıt Paylaş
Great guide - my 12 year old son was able to get through it with a little help from me. Nice work.
smo2 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 44
Her zaman: 2,240
